คะแนน 1161
ออฟไลน์
« ตอบ #2 เมื่อ: มีนาคม 07, 2011, 11:57:17 pm » |
แอร์ Sanyo
A CODES GHP ENGINE ISSUES
Code Description
A01 GHP - Engine oil pressure fault A02 GHP - Engine oil level fault A03 GHP - Engine over speed A04 GHP - Engine under speed A05 GHP - Ignition power supply failure A06 GHP - Engine start up failure A07 GHP - Fuel gas valve failure A08 GHP - Engine stalled
A09 GHP - Engine overload A10 GHP - High exaust gas temp A11 GHP - Engine oil level failure A12 GHP - Throttle actuator fault A13 GHP - Fuel gas valve adjustment failure A14 GHP - Engine oil pressure sensor fault A15 GHP - Starter power output short circuit A16 GHP - Starter motor locked A17 GHP - Starter current (CT) coil failed A19 GHP - Wax Valve (3 Way) fault A20 GHP - Cooling water temp high A21 GHP - Cooling water level fault A22 GHP - Cooling water pump fault A23 GHP - Engine crank angle sensor failure A24 GHP - Engine cam angle sensor failure A25 GHP - Clutch fault A26 GHP - Misfire A27 GHP - Catalyst temperature fault A28 GHP - Generator fault A29 GHP - Converter fault A30 GHP - Fuel gas pressure low
C CODES CENTRAL CONTROLLER ISSUES
Code Description
C01 Duplicated setting of control address C02 Central control number of units mis-
matched C03 Incorrect wiring of central control C04 Incorrect connection of central control C05 System Controller fault, error in
transmiting comms signal, i/door or o/door
unit not working, wiring fault C06 System Controller fault, error in
receiving comms signal, i/door or o/door
unit not working, wiring fault, CN1 not
connected correctly C12 Batch alarm by local controller C16 Transmission error from adaptor to unit C17 Reception error to adaptor from unit C18 Duplicate central address in adaptor C19 Duplicate adaptor address C20 Mix of PAC & GHP type units on adaptor C21 Memory fault in adaptor C22 Incorrect address setting in adaptor C23 Host terminal software failure C24 Host terminal hardware failure C25 Host terminal processing failure C26 Host terminal comunication failure C28 Reception error of S-DDC from host
terminal C29 Initialization failure of S-DDC C31 Configuration change detected by adaptor
E CODES ADDRESSING COMMUNICATION PROBLEMS
Code Description
E01 Remote control detecting error from
indoor unit, Address not set/Auto address
failed. Check interconnecting wiring etc.
Re-address system. E02 Remote detecting error from indoor unit, E03 Indoor unit detecting error from remote, E04 Indoor seeing error from outdoor. Qty of
i/d units connected are less than qty set.
Check; all i/d units are ON, reset turn off all units wait 5min power up E05 Indoor unit detecting error from outdoor
unit, Error in sending comms signal E06 Outdoor unit detecting error from indoor
unit, Error in receiving comms signal E07 Outdoor unit detecting error from indoor
unit, Error in sending comms signal E08 Incorrect setting indoor/controller,
Indoor address duplicated E09 Incorrect setting indoor/controller,
Remote address duplicated or IR wireless
controller not disabled E10 Indoor unit detecting error from
'option' plug, Error in sending comms signal E11 Indoor unit detecting error from
'option' plug, Error in receiving comms
signal E12 Auto addressing failed, Auto address
connector CN100 shorted during auto
addressing E13 Indoor unit failed to send signal to
remote controller E14 Setting Failure, Duplication of master
indoor units E15 Auto addressing failed, Number of indoor
units connected are less than number set E16 Auto addressing failed, Number of indoor
units connected are more than number set E17 Group control wiring error, Main indoor
unit not sending signal for sub indoor units E18 Group control wiring error, Main indoor
unit not receiving signal for sub indoor
units E20 Auto addressing failed, No indoor units
connected E24 Auto addressing failed, Error on sub
outdoor unit E25 Auto addressing failed, Error on outdoor
unit address setting E26 Auto addressing failed, Quantity of main
and sub outdoor units do not correspond to
the number set on main outdoor unit P.C.B. E29 Auto addressing failed, Sub outdoor unit
not receiving comms for main outdoor unit E31 Between units, Comms failure with MDC,
does E31 remain after power is re instated?
If so replace PCB. & power PCB
F & H CODES SENSOR FAULTS
Code Description
F01 Indoor Heat Exch inlet temp sensor
failure (E1) F02 Indoor Heat Exch freeze temp sensor
failure (E2) F03 Indoor Heat Exch outlet temp sensor
failure (E3) F04 Outdoor Discharge temp sensor failure
(TD) or (DISCH1) F05 Outdoor Discharge temp sensor failure
(DISCH2) F06 Outdoor Heat Exch temp sensor failure
(C1) or (EXG1) F07 Outdoor Heat Exch temp sensor failure
(C2) or (EXL1) F08 Outdoor Air temp sensor failure (TO) F10 Indoor inlet temp sensor failure F11 Indoor outlet temp sensor failure F12 Outdoor Intake sensor failure (TS) F13 GHP - Cooling water temperature sensor
failure F16 Outdoor High pressure sensor failure F17 GHP - Cooling water temperature sensor
fault F18 GHP - Exhaust gas temperature sensor
fault F20 GHP Clutch coil temperature fault F23 Outdoor Heat Exch temp sensor failure
(EXG2) F24 Outdoor Heat Exch temp sensor failure
(EXL2) F29 Indoor EEPROM error F30 Clock Function (RTC) fault F31 Outdoor EEPROM error
COMPRESSOR ISSUES
Code Description
H01 Compressor Fault, Over current (Comp1) H02 Compressor Fault, Locked rota current
detected (Comp1) H03 Compressor Fault, No current detected
(Comp1) H05 Compressor Fault, Discharge temp not
detected (Comp1) H06 Compressor Fault, Low Pressure trip H07 Compressor Fault, Low oil level H08 Compressor Fault, Oil sensor Fault
(Comp1) H11 Compressor Fault, Over current (Comp2) H12 Compressor Fault, Locked rota current
detected (Comp2) H13 Compressor Fault, No current detected
(Comp2) H15 Compressor Fault, Discharge temp not
detected (Comp2) H27 Compressor Fault, Oil sensor fault
(Comp2) H28 Compressor Fault. Oil sensor (connection
failure) H31 Compressor Fault. IPM trip (IMP current
on temperature
L CODES INCORRECT SETTINGS
Code Description
L01 Setting Error, Indoor unit group setting
error L02 Setting Error, Indoor/outdoor unit
type/model miss-matched L03 Duplication of main indoor unit address
in group control L04 Duplication of outdoor unit system
address L05 2 or more controllers have been set as
'priority' in one system - shown on
controllers set as 'priority' L06 2 or more controllers have been set as
controllers not set as 'priority' L07 Group wiring connected on and indvidual
indoor unit L08 Indoor unit address/group not set L09 Indoor unit capacity code not set L10 Outdoor unit capacity code not set L11 Group contol wiring incorrect L13 Indoor unit type setting error, capacity L15 Indoor unit paring fault L16 Water heat exch unit setting failure L17 Miss-match of outdoor unit with
different refrigerant L18 4-way valve failure L19 Water heat exch unit duplicated address L21 Gas type setup failure
P CODES - INDOOR UNIT PROBLEMS
Code Description
P01 Indoor unit fault, Fan motor thermal
overload P02 Outdoor unit fault, Compressor motor
thermal overload, over or under voltage P03 Outdoor unit fault, Compressor discharge
temperature too high (Comp1) over 111 degC.
Low on ref gas, exp valve, pipework damage. P04 Outdoor unit fault, High pressure trip P05 Outdoor unit fault, Open phase on power
supply. Check power on each phase, inverter
pcb, control pcb P09 Indoor unit fault, Ceiling panel
incorrectly wired P10 Indoor unit fault, Condensate float
switch opened P11 GHP - Water Heat exch low temp (frost
protection) fault P12 Indoor unit fault, Fan DC motor fault P14 Input from leak detector (If fitted) P15 Refrigerant loss, high discharge temp
and EEV wide open and low compressor current
draw. P16 Outdoor unit fault, Open phase on
compressor power supply P17 Outdoor unit fault, Compressor discharge
temperature too high (Comp2) over 111 degC.
Low on ref gas, exp valve, pipework damage. P18 Outdoor unit fault, By-pass valve
failure P19 Outdoor unit fault, 4 way valve failure,
i/door temp rises in cooling or fulls in
heating. Check wiring, coil, pcb output,
valave operation. P20 Ref gas, high temp/pressure fault, heat
exch temp high C2, 55-60 degC, cooling over
-load, sensor fault. P22 Outdoor unit fan motor fault, fan blade
jammed, check connections, does fan turn
freely, motor resistance 30-40ohm on each
pair, no fan fault, yes pcb fault. P26 Outdoor unit fault, Compressor
overcurrent - check winding resistance,
Inverter failure - check internal resistance
term HIC + & - to UVW 200-300Kohm or more P29 Outdoor unit fault, Inverter circuit
fault - Motor-current Detection Circuit
(MDC) fault, check comp windings, sensors C1
& TS, if ok possible pcb failure. P30 Indoor unit fault, System controller
detected fault on sub indoor unit P31 Simultaneous operation multi control
fault, Group controller fault
