Error code Canon mp258
พฤศจิกายน 26, 2024, 12:39:05 am *
ผู้เขียน หัวข้อ: Error code Canon mp258  (อ่าน 6282 ครั้ง)
prasert_sms
คะแนน40
กระทู้: 218
« เมื่อ: ตุลาคม 23, 2009, 05:30:32 pm »
1.  Carriage error P02 An error occurred in the carriage encoder signal.
            1) Confirm that no foreign material is in the area where the carriage moves.
            2) Clean the timing slit film.
            3) Replace the following items:
                        - Timing slit film
                        - Carriage unit
                        - Logic board
                        - Carriage motor
2. Line feed error  P03 An error occurred in the LF encoder signal.
                        - Timing slit disk film
                        - Logic board
3.  ASF cam sensor error P05 This error takes place when feeding paper
            from the rear tray after an error occurred in the rear tray cam sensor.
                        - ASF/PE sensor unit
                        - Drive unit
                        - Logic board
4. Internal temperature error  P06 The internal temperature is not normal.
            Replace the following item:
                        - Logic board
5. Ink absorber full Japan:  Others:  P07 The ink absorber becomes full.
            Replace the ink absorber (ink absorber kit), and reset the ink absorber counter.
6. Print head temperature rise error  P08 The print head temperature exceeded the   specified value.
                        - Ink cartridge
                        - Logic board
7. EEPROM error  P09 A problem occurred in reading from or writing to the EEPROM.
                        - Logic board
8. VH monitor error  P10 The print head voltage is abnormal.
                        - Ink cartridge
                        - Logic board
9. USB VBUS overcurrent  P15 The USB VBUS is overloaded.
                        - Logic board
10.Other hardware error  P20
                        - Logic board
11 Scanner error  P22 The scanner unit is faulty.
                        - Scanner unit
                        - Logic board
aonelka
กระทู้: 236
ไม่ได้เป็นช่างมืออาชีพ แต่มีอาชีพเป็นช่าง
« ตอบ #1 เมื่อ: ตุลาคม 24, 2009, 06:59:54 pm »
P 16 ด้วยครับ...
 Sad try!!
