Error Code Canon ตระกูล MP ไม่รู้มีกันรึยังนะครับ(แปลกันเอาเองนะครับ)
พฤศจิกายน 25, 2024, 06:43:12 am *
ผู้เขียน หัวข้อ: Error Code Canon ตระกูล MP ไม่รู้มีกันรึยังนะครับ(แปลกันเอาเองนะครับ)  (อ่าน 3139 ครั้ง)
whitecrow
คะแนน32
กระทู้: 547
« เมื่อ: กรกฎาคม 24, 2009, 10:28:46 pm »
Error Code Canon MP
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 The connected digital camera / video camera does not support Camera Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed
E16 Ink remaining is unknown
E19 Failed to scan head alignment sheet
Е22 Carriage error
Е23 Paper feed error
Е24 Purge unit error
Е25 ASF(cam) sensor error
Е26 Internal temperature rise error
Е27 Waste ink absorber full or platen waste ink absorber full
Е28 Ink cartridge temperature rise error -
Е29 EEPROM error
Е33 Paper feed position error
Е35 USB Host VBUD overcurrent error - USB
Е37 Abnormal motor driver error
Е40 Other hardware error
Е42 Scanner error
วิธีปฏิบัติ
E2
Reload the paper correctly and press [Black> or [Color>.
E3
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black> or [Color>.
E4
The ink may have run out. Replace the FINE Cartridge, and close the Scanning Unit. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment. If printing is in progress and you want to continue printing, press [Black> or [Color>. Then printing can continue under the ink out condition with the FINE Cartridge installed. Replace the empty FINE Cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
E5
The FINE Cartridge may not be installed properly, or the Cartridge may not be the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
E7
Some FINE Cartridges are not installed in place. Install the FINE Cartridges in the appropriate positions.
E8
Waste ink absorber is almost full. Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. indicates that the waste ink absorber is nearly full. Press [Black> or [Color> to cancel the error so that you can continue printing. If this error occurs, replacement of the waste ink absorber and maintenance of the machine are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
E9
Depending on the model or brand of your device, you may have to select a print mode compliant with PictBridge before connecting the device.
You may also have to turn on the device or select Play mode manually after connecting the device to the machine. Perform necessary operations according to the instruction manual supplied with your device.
If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this machine. Use a digital camera or digital video camcorder compatible with this machine.
E14
The FINE Cartridge may not be the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
E15
FINE Cartridge errors have occurred. Replace the FINE Cartridge.
E16
This FINE Cartridge may have previously been used, or the ink may have run out. The function for detecting the remaining ink level will be disabled since the remaining ink level cannot be correctly detected. If you want to continue printing without this function, press [Black> or [Color>. Canon recommends to use new genuine Canon Cartridges in order to obtain optimum qualities.
E19
The size of the document cannot be correctly detected or the document is too small when the Fit-to-Page copying is selected. Make sure the document meets the requirements and correctly loaded on the Platen Glass. Then reload the document and press [Black> or [Color>. See Setting Documents.
E2x
E3x
E4x
An error requiring servicing might have occurred. Turn OFF the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn ON the machine. If the same error occurs, contact a Canon service representative.
