ขอปริมาตรตู้เปิดซับ Proplus 10 นิ้ว ขนาดท่อ ความยาวท่อ ด้วยค๊าบบ วางใส่ท้ายรถ Honda City 97 คับ ขอบคุนล่วงหน้าคับ --------------------------------------------------------
--- BassBox Pro Version 4.00, Export Thiele-Small Format
--- Jun 24,2009, Wed 10:42AM
--- PROPLUS : D-MAX 10
--- Parameters marked with ** are not tested using the WT2
--- mechanical ---
Fs 46.178E+00 Hz Free air resonance
Qms 11.469E+00 Q mechanical
Vas 22.250E-03 m^3 Suspension compliance
Cms 143.771E-06 m/N 1/(suspension stiffness)
Mms 82.623E-03 kg Moving mass
Rms 2.090E+00 kg/s Mechanical resistance
Xmax ** 0.000E+00 m Maximum acoustic linear motion
Xmech** 0.000E+00 m Mechanical displacement
Dia 205.000E-03 m Piston diameter
Sd 33.006E-03 m^2 Piston area
Vd ** 0.000E+00 m^3 Displacement volume
--- electrical ---
Qes 2.313E+00 Q electrical
Re 3.516E+00 ohms Voice coil DC resistance
Le 766.991E-06 Henries Inductance @1 kHz
Z 7.432E+00 ohms Impedance @1 kHz
BL 6.037E+00 Tm Motor force - Newtons/Amp
Pe ** 0.000E+00 W Max Electrical Power
--- electro-mechanical ---
Qts 1.925E+00 Q total
no 89.006E-03 % 1/2-space ref efficiency @ 1m/1W
1-W SPL 81.512E+00 dB sensitivity at 1m on-axis
2.83V SPL 85.083E+00 dB sensitivity at 1m on-axis
--- motor constants ---
Krm 160.324E-06 ohms constant resistive motor impedance
Erm 1.073E+00 exponent resistive motor impedance
Kxm 5.949E-03 Henries constant reactive motor impedance
Exm 762.228E-03 exponent reactive motor impedance
--- End BassBox Pro Export ---
ขอบคุณล่วงหน้าคับ
