ช่วยแปลให้หน่อยครับ
พฤศจิกายน 24, 2024, 06:03:49 am *
ผู้เขียน หัวข้อ: ช่วยแปลให้หน่อยครับ  (อ่าน 2123 ครั้ง)
bogie
กระทู้: 138
« เมื่อ: เมษายน 18, 2008, 03:02:51 pm »
[color=red]Soft start and standby[/color]
If HPLL2 is pulled to ground by resetting the register
SOFTST, the horizontal output pulses, vertical output
currents and B+ control driver pulses will be inhibited. This
means that HDRV (pin Cool, BDRV (pin 6), VOUT1 (pin 13)
and VOUT2 (pin 12) are floating in this state. If HPLL2 is
pulled to ground by an external DC current, vertical output
currents stay active while HDRV (pin Cool and BDRV (pin 6)
are in floating state. In both cases the PLL2 and the
frequency-locked loop are disabled, CLBL (pin 16)
provides a continuous blanking signal and HUNLOCK
(pin 17) is floating.
This option can be used for soft start, protection and
power-down modes. When the HPLL2 pin is released
again, an automatic soft start sequence on the horizontal
drive as well as on the B+ drive output will be performed
(see Figs 24 and 25).
A soft start can only be performed if the supply voltage for
the IC is a minimum of 8.6 V.
The soft start timing is determined by the filter capacitor at
HPLL2 (pin 30), which is charged with a constant current
during soft start. If the voltage at pin 30 (HPLL2) reaches
1.1 V, the vertical output currents are enabled. At 1.7 V the
horizontal driver stage generates very small output pulses.
The width of these pulses increases with the voltage at
HPLL2 until the final duty cycle is reached. The voltage at
HPLL2 increases further and performs a soft start at BDRV
(pin 6) as well. The voltage at HPLL2 continues to rise until
HPLL2 enters its normal operating range. The internal
charge current is now disabled. Finally PLL2 and the
frequency-locked loop are activated. If both functions
reach normal operation, HUNLOCK (pin 17) switches from
the floating status to normal vertical blanking, and
continuous blanking at CLBL (pin 16) is removed.
Output stage for line drive pulses [HDRV (pin Cool]
An open-collector output stage allows direct drive of an
inverting driver transistor because of a low saturation
voltage of 0.3 V at 20 mA. To protect the line deflection
transistor, the output stage is disabled (floating) for a low
supply voltage at VCC (see Fig.23).
The duty cycle of line drive pulses is slightly dependent on
the actual horizontal frequency. This ensures optimum
drive conditions over the whole frequency range.
X-ray protection
The X-ray protection input XRAY (pin 2) provides a voltage
detector with a precise threshold. If the input voltage at
XRAY exceeds this threshold level for a certain time then
control bit SOFTST is reset, which switches the IC into
protection mode. In this mode several pins are forced into
defined states:
HUNLOCK (pin 17) is floating
The capacitor connected to HPLL2 (pin 30) is
discharged
Horizontal output stage (HDRV) is floating
B+ control driver stage (BDRV) is floating
Vertical output stages (VOUT1 and VOUT2) are floating
CLBL provides a continuous blanking signal.
There are two different methods of restarting the IC:
1. XSEL (pin 9) is open-circuit or connected to ground.
The control bit SOFTST must be set to logic 1 via the
I2C-bus. The IC then returns to normal operation via
soft start.
2. XSEL (pin 9) is connected to VCC via an external
resistor. The supply voltage of the IC must be switched
off for a certain period of time before the IC can be
restarted again using the standard power-on
procedure.
Vertical oscillator and amplitude control
This stage is designed for fast stabilization of vertical
