Program Home Plan Pro 5 2 12 4
พฤศจิกายน 25, 2024, 10:58:28 am *
ผู้เขียน หัวข้อ: Program Home Plan Pro 5 2 12 4  (อ่าน 4234 ครั้ง)
eskimo_bkk-LSV team♥
คะแนน1887
กระทู้: 13886
ไม่แล่เนื้อเถือหนังพวก
« เมื่อ: มีนาคม 15, 2008, 01:10:51 pm »
Credit TheSearcher
Want to build your dream house? Add a room to your home? Whatever your drawing needs, Home Plan Pro is your best choice.
Home Plan Pro is designed to quickly and easily draw high quality floor plans, site plans, and architectural designs.
             Home Plan Pro provides a full array of graphic tool buttons to let you easily pick a tool or action. Once you choose a tool, Home Plan Pro tells you how to use it. You may use the mouse or keyboard, or both, to create your plan.
Home Plan Pro gives you many choices for printing your plans. You may select a specific scale, or elect to have your plan printed at the largest size that will fit on the paper you select.
             While there are a number of impressive and powerful CAD programs available, they are more difficult to learn and use than Home Plan Pro. To preserve its intuitive ease of use and low cost, Home Plan Pro is not designed to compete with full-fledged CAD programs.
                  Home Plan Pro includes the home design tools you need:
* Easily draw arcs, rectangles, circles, lines, and so forth.
* Use the mouse, keyboard, or a combination of both.
* Add scaled dimensions with two clicks.
* Insert doors and windows with equal ease.
* Zoom in or out with a click to work on detailed parts of the plan or to see the whole of it.
* Create Layers that you can make invisible or visible at a click
* Draw a plot plan using metes & bounds. Calculate the area and acreage.
                     New in version 5.1:
* Zoom from 6400' to 1/32"
* Detailed Print Preview
* Draw a Series of Parallel Lines
* Draw Double Walled Rectangles
* Wall Thickness in Fractions
* Windows widths and patterns
* Metes & Bounds
* Prevent Printed Text From Scaling Too Big
* Create a Column of Text
* Snap Grid spacing is saved for each zoom level)
* Speed settings are also saved separately for each zoom level.
* New Zoom Bar buttons provide instant zooming to any level
download here size 3.05 MB
