ตัวย่อและความหมายทางelectronics(ในบางวงจร)
พฤศจิกายน 22, 2024, 11:53:58 am *
ผู้เขียน หัวข้อ: ตัวย่อและความหมายทางelectronics(ในบางวงจร)  (อ่าน 12745 ครั้ง)
ช้าง ณ.ปากพนัง -LSV team
คะแนน112
กระทู้: 143
« เมื่อ: มกราคม 20, 2007, 10:01:39 pm »
ย้ายมาจาก http://www.leksound.net/forum/index.php?topic=3394.0
team >กลุ่มผู้มีน้ำใจ
Electronics Reference: Acronyms
A
A Amperes
AC Alternating Current
A/D Analog to Digital
ADC Analog to Digital Converter
AE Applications Engineer
AI Artificial Intelligence
ALU Arithmetic-Logic Unit
AM Amplitude Modulation
AMD Advanced Micro Devices, Inc.
ANSI American National Standards Institute
ARQ Automatic Retransmission reQuest
ASCII American Standard Code for Information Interchange
ASEE American Society for Engineering Education
ASIC Application Specific Integrated Circuit
ASPI Advanced SCSI Programming Interface
ATDM Asynchronous Time Division Multiplexing
ATM Asynchronous Transfer Mode
AUI Attached Unit Interface
B
B Magnetic Flux
BBS Bulletin Board System
BCC Block Check Character
BCD Binary Coded Decimal
BiCMOS Bipolar Complementary Metal-Oxide Semiconductor
BIOS Basic Input / Output System
BNC Bayonet Nut(?) Connector
BPS/bps Bytes/bits Per Second
BSC Binary Synchronous Communications
BSD Berkeley Standard Distribution
C
C Capacitance
CAD Computer Aided Design
CAM Computer Aided Manufacturing
CAM Content Addressable Memory
CAS Column Address Strobe
CBX Common Branch eXtender
CCD Charge Coupled Device
CCITT Consultative Committee of International Telephony and Telegraphy
CD Carrier Detect
CDDI Copper Distributed Data Interface
CDROM Compact Disk Read Only Memory
CDMA Code Division Multiple Access
CGA Color Graphics Adapter
CISC Complex Instruction-Set Computer
CLA Carry Look-ahead Adder
CMOS Complementary Metal-Oxide Semiconductor
CP/M Control Program / Monitor
CPI Clocks Per Instruction
CPLD Complex Programmable Logic Device
CPU Central Processing Unit
CR Carriage Return
CRC Cyclic Redundancy Code
CRQ Command Response Queue
CRT Cathode Ray Tube
CS Chip Select / Check-Sum
CSMA Carrier Sense Multiple-Access
CSMA/CD Carrier Sense Multiple-Access with Collision Detect
CSR Command Status Register
CTS Clear To Send
D
D Dissipation Factor
D/A Digital to Analog
DAC Digital to Analog Converter
DAT Digital Audio Tape
dB (DB) deciBels
dBm dB referenced to 1 milliWatt
DC Direct Current
DCD Data Carrier Detect
DCE Data Circuit (Channel) Equipment
DD Double Density
DDD Direct Distance Dialing
DEC Digital Equipment Corporation
DES Data Encryption Standard
DID Direct Inward Dial
DIN Deutsche Industrie Norm
DIP Dual-In-line Package
DMA Direct Memory Access
DOS Disk Operating System
DPDT Double-Pole Double-Throw (switch)
DPE Data Parity Error
DPSK Differential Phase Shift Keying
DRAM Dynamic Random Access Memory
DS Double Sided
DSP Digital Signal Processor
DSR Data Set Ready
DTC Data Terminal Controller
DTE Data Terminal (Terminating) Equipment
DTMF Dual-Tone Multi-Frequency
DTR Data Terminal Ready
DVD Digital Video Disk
E
E EMF
EBCDIC Extended Binary Coded Decimal Interchange Code
ECC Error Correction Code
ECL Emitter-Coupled Logic
ECN Engineering Change Notice
ECO Engineering Change Order
ECR Engineering Change Request
EEPROM Electrically Erasable Programmable Read-Only Memory
EGA Enhanced Graphics Adapter
EIA Electronic Industries Association
EISA Enhanced Industry Standard Architecture
EMI Electro-Magnetic Interference
EMF Electro-Motive Force
EMS Expanded Memory Specification
EOF End Of File
EOL End Of Line
EPROM Erasable Programmable Read-Only Memory
ESD Electro-Static Discharge
ESDI Enhanced Small Devices Interface
F
F Farads
FAT File Allocation Table
FCC Federal Communications Commission
FDD Floppy Disk Drive
FDDI Fiber Distributed Data Interface
FDM Frequency Division Multiplexing
FDMA Frequency Division Multiple Access
FDX Full-Duplex Transmission
FE Front End
FEP Front End Processor
FF Form Feed
FF Flip-Flop
FFT Fast Fourier Transform
FIFO First-In First-Out
FILO First-In Last-Out
FLOPS Floating-point Operations Per Second
FM Frequency Modulation
FPGA Field Programmable Gate Array
FPU Floating Point Unit
FRU Field-Replaceable Unit
FSK Frequency Shifty Keying
FTP File Transfer Program
G - H - I
G Giga
GAs Gallium Arsenide
GFLOPS Billions (10^9) of FLOating Point Operations Per Second ("Giga-Flops")
GHz Giga Hertz
GNU Gnu's Not Unix
GPIB General Purpose Interface Bus
GUI Graphical User Interface
H Henries
H Magnetic Force
HD High Density
HDD Hard Disk Drive
HDX Half-Duplex Transmission
HFS Hierarchical File System
HP Hewlett-Packard
I Current
HPIB Hewlett-Packard Interface Bus
I/O Input / Output
IBM International Business Machines Corp.
IC Integrated Circuit
IDC Insulation Displacement Connector
IDE Integrated Device Electronics
IEEE Institute of Electrical and Electronic Engineers
IMP Interface Message Processor
IP Internet Protocol
IPC InterProcess Communication
IRQ Interrupt ReQuest
ISA Industry Standard Architecture
ISDN Integrated Services Digital Network
ISO International Standards Organization
ISP ISP Internet Service Provider
J - K - L
J Joules of energy
K Kilo
KVA Kilo Volt-Amps
LAN Local Area Network
LAP Link Access Protocol
LAPB Link Access Protocol Balanced
LCD Liquid Crystal Display
LED Light Emitting Diode
LF Line Feed
LIFO Last In First Out
LSB Least Significant Bit (or Byte)
LSI Large Scale Integration
LUN Logical Unit Number
M
M Mega
m milli
MAN Metropolitan Area Network
MB Mega Bytes
MBR Master Boot Record
MCA Micro Channel Architecture
MCGA Multi-Color Graphics Array
MCM Multi-Chip Module
mfd micro Farads
MFLOPS Millions of FLOating Point Operations per Second ("MegaFlops")
MFM Modified Frequency Modulated
MHz MegaHertz
MIDI Musical Instrument Digital Interface
MIPS Millions of Instructions per Second
MMU Memory Management Unit
MNP Microcom Network Protocol
MODEM MOdulator / DEModulator
MOPS Millions of Operations Per Second
MOS Metal-Oxide Semiconductor
MSB Most Significant Bit (or Byte)
MSDOS Microsoft Disk Operating System
MSI Medium Scale Integration
MTBF Mean Time Between Failures
N - O
n nano
NAND Not And
N/C No-Connect
NBS National Bureau of Standards
NEMA National Electrical Manufacturers Association
NFS Network File System
NIC Network Interface Card
NIST National Institute of Standards and Technology
NMI Non-Maskable Interrupt
NMOS Negatively doped Metal-Oxide Semiconductor
NOP No OPeration
NSF National Science Foundation
NVRAM NonVolatile Random Access Memory
OCR Optical Character Recognition
ODI Open Datalink Interface
OEM Original Equipment Manufacturer
OS Operating System
OSF Open Software Foundation
OSI Open Systems Interconnect
P
p pico
PAL Programmable Array Logic
PLA Programmable Logic Array
PB Push Button
PBX Private Branch eXchange
PC Personal Computer, Program Counter
PCB Printed Circuit Board
PCI Peripheral Component Interconnect
PCM Pulse Code Modulation
PCMCIA Personal Computer Memory Card International Association
PE Professional Engineer
PGA Pin Grid Array
PIA Peripheral Interface Adapter
PIC Programmable Interrupt Controller
PIO Programmed Input/Output
PLCC Plastic Leaded Chip Carrier
PLD Programmable Logic Device
PLL Phase Locked Loop
PMOS Positively doped Metal-Oxide Semiconductor
POP Post Office Protocol (email)
POST Power On Self Test
POTS Plain Old Telephone Service
PPP Point-to-Point Protocol
PQFP Plastic Quad-FlatPack
PROM Programmable Read-Only Memory
PSTN Public Switched Telephone Network
Q - R
Q Charge
QAM Quadrature Amplitude Modulation
QFP Quad-FlatPack
R Resistance
RAM Random Access Memory
RAS Row Address Strobe
RCA Radio Corporation of America
R/C Radio Control
RC Resistor - Capacitor
RF Radio Frequency
RFC Radio Frequency Choke
RFI Radio Frequency Interference
RFP Request For Proposal
RFQ Request For Quotation
RI Ring Indicator
RISC Reduced Instruction-Set Computer
RLL Run Length Limited
RMS Root Mean Square
ROM Read-Only Memory
RPM Revolutions Per Minute
RS Recommended Specification
RTC Real Time Clock
RTS Request To Send
S
S Siemens
SASI Shugart Associates Standard Interface
SCSI Small Computer Systems Interface
SD Single Density
SDLC Synchronous Data Link Control
SIMM Single Inline Memory Module
SIP Single Inline Package
SLIP Serial Line Internet Protocol
SMD Surface Mount Device
SMT Surface Mount Technology
SNA System Network Architecture
SNR Signal to Noise Ratio
SOT Small Outline Transistor
SOIC Small Outline Integrated Circuit
SPOOL Simultaneous Peripheral Operation On Line
SPST Single-Pole Single-Throw (switch)
SPT Sectors Per Track
SQE Signal Quality Error
SRAM Static Random Access Memory
SS Single Sided
STDM Synchronous Time Division Multiplexing
STN Super Twisted Nematic
STP Shielded Twisted Pair
STU Streaming Tape Unit
SVGA Super Video Graphics Array
T
TCM Trellis Code Modulation
TCP/IP Transmission Control Protocol / Internet Protocol
TDM Time Division Multiplexing
TDMA Time Division Multiple Access
TI Texas Instruments
TIA Telecomm. Industry Assocation
TPI Tracks Per Inch
TSR Terminate and Stay Resident
TTL Transistor-Transistor Logic
TUV Technischer Ueberwachuags Verein
U - V
UV Ultra Violet
UART Universal Asynchronous Receiver/Transmitter
UDP User Datagram Protocol
UMB Upper Memory Block
UPS Uninterruptible Power Supply
UTP Unshielded Twisted Pair
UUCP Unix to Unix Copy Program
VCR Video Cassette Recorder
VESA Video Enhanced Standards Association
VGA Video Graphics Array
VLB VESA Local Bus
VLSI Very Large Scale Integration
VM Virtual Memory
VME Versa Module Eurocard
VRAM Video Random Access Memory
VTR Video Tape Recorder
W - X - Y - Z
W Watts
WAN Wide Area Network
WATS Wide Area Telephone Service
WORM Write-Once Read-Many
WWW World Wide Web
XGA eXtended Graphics Array
XMS Extended Memory Specification
XOR Exclusive-Or
Y Admittance
Z Impedance
ZIF Zero Insertion Force
somsak47 > บุคคลทั่วไป
   Re: ตัวย่อและความหมายทางelectronics(ในบางวงจร)
« ตอบ #1 เมื่อ: 16 มกราคม 2005, 11:51:04 »
Anode แอโนด
Antenna  สายอากาศ
Indoor antenna สายอากาศภายใน
Outdoor antenna  สายอากาศภายนอก
Folded dipole antenna  ส่ายอากาศแบบ โฟลเดด ไดโพล
Conical antenna สายอากาศรูปทรงกรวย
Amplifier  เครื่องขยายสัญญาณ เครื่องขยาย กำลังสัญญาณ
Power amplifier  เครื่องขยายกำลังสัญญาณ
Voltage amplifier  เครื่องขยายสัญญาณ
A F amplifier (audio-frequency amplifier) เครื่องขยายสัญญาณเสียง
R F amplifier (radio-frequency amplifier) เครื่องขยายสัญญาณโทรทัศน์
Video amplifier เครื่องขยายสัญญาณภาพ
Audio amplifier  เครื่องขยายสัญญาณเสียง
Video IF amplifier  เครื่องขยายสัญญาณ ไอ.เอฟ. คลื่นพาห์ของภาพ
Audio IF amplifier เครื่องขยายสัญญาณ ไอ.เอฟ. คลื่นพาห์ของเสียง
Grounded - cathode amplifier  เครื่องขยายสัญญาณชนิดต่อคาโถดลงดิน
Grounded - grid amplifier  เครื่องขยายสัญญาณชนิดต่อกริดลงดิน
Ampare  แอมป์
Ammeter  แอมป์มีเตอร์
AGC (automatic gain control)  ส่วนควบคุมการขยายสัญญาณอัตโนมัติ
AGC circuit  วงจร เอ.จี.ซี. วงจรควบคุมการขยายอัตโนมัติ
Amplitude  ขนาด , ช่วงกว้างของคลื่น
AM (amplitude modulation)  เอ.เอ็ม.
- B -
battery แบตเตอร
bandwidth แบนด์ วิดธ
blanking signal  สัญญาณแบ้ลงค์กิ้ง
boosted voltage บูชเทด โวลเทจ
biasing voltage ไบแอชชิ่ง โวลเทจ
brightness control  ส่วนควบคุมความสว่างของภาพ
bridge circuit วงจรบริดจ์
- C -
casrrier  ตัวพาห์
carrier wave คลื่นพาห์
camera  กล้องโทรทัศน์
cathode  แคโถด
charge ประจุ
characteristics คุณลักษณะ
channel selector สวิทช์เปลี่ยนช่องโทรทัศน
chassis แชซซิส
T v chanel  ช่องโทรทัศน์
Coil คอยล์ , ขดลวด
Coil pitch  พิทช์ของคอยล์
Contrast control ส่วนควบคุมความแตกต่าของภาพ , คอนแทรสท์
Composite video signal  สัญญาณภาพรวม
Condenser } capacitor  คอนแดนเซอร
Cut - off voltage คัทอ็อฟ โวลเทจ
Cycle per second , Hertz  รอบต่อวินาที , เฮิทซ
Mc / s, MHz  เมกกะเฮิทซ์
Kc / c,kHz กิโลเฮทซ์
Current  กระแส
Sawtooth Current  กระแสรูปฟันเลี่อย
Control  ส่วนควบคุม
Hold Control  ส่วนควบคุมความถี่
Vertical hold control  ส่วนควบคุมความถี่ทางแนวตั้ง
Horizontal hold control  ส่วนควบคุมความถี่ทางแนวนอน
Height control  ส่วนควบคุมความสูงของภาพ
Linearity control  ส่วนควบคุมรูปร่างของกระแสรูปฟันเลื่อย
Vertical linearity control  ส่วนควบคุมรูปร่างของกระแสรูปฟันเลื่อยในวงจรการหักเหทาง แนวตั้ง
horizontal linearity control  ส่วนควบคุมรูปร่างของกระแสรูปฟันเลื่อยในวงจรการหักเหทาง แนวนอน
fine turning control ไฟน์ ทูนนิ่ง
contrast control ส่วนควบคุมความแตกต่างของภาพ , คอนแทรสท์
volume control  ส่วนควบคุมความดังของเสียง
width control  ส่วนควบคุมความกว้างของภาพทางแนวนอน
focus  ส่วนควบคุมโฟกัส
circuit  วงจร
mixer circuit  วงจรผสมสัญญาณ
cascode amplifier circuit  วงจรขยายสัญญาณแบบ แคสโคด
coupling condenser  คัพปลิง คอนเดนเซอร์
contrast  คอนแทรสท์
- D -
deflection ดีเฟลคชั่น , การหักเห
vertical deflection circuit  วงจรการหักเหทางแนวตั้ง
horizontal deflection circuit วงจรหักเหทางแนวนอน
vertical deflection coil  คอยล์ของการหักเหทางแนวตั้ง
detector circuit  วงจรดีเทคเตอร์
video detector circuit  วงจรดีเทคเตอร์ด้านภาพ
audio detector circuit  วงจรดีเทคเตอร์ด้านเสียง
damper  แดมเปอร์
deflection yoke  ดีเฟล็กชั่น โย๊ค
- E -
electron  อิเล็กตรอน
equalizing pulse signal  สัญญาณอีควอไลซิ่ง frequency ความถ
- F -
IF (intermediate frequency) ความถี่ ไอ.เอฟ.
MF (medium frequency) ความถี่ปานกลาง
HF (high frequency) ความถี่สูง
VHF (very high frequency) ความถี่สูงมาก
Frequency spectrum สเปคตรัมของความถ
Farad  ฟารัด
Microfarad  ไมโครฟารัด
Picofarad พิโคฟารัด
Feeder line สายฟีเดอร์
Frame เฟรม (ภาพ)
Frame frequency ความถี่เฟรม (ภาพ)
Field ฟิลด์
Field frequency ความถี่ฟิลด์
Odd field scanning การสแกนฟิลด์เส้นค
Even field scanning  การสแกนฟิลด์เส้นค
Frequency control ส่วนควบคุมความถี่
AFC (automatic frequency control)  ส่วนควบคุมความถี่อัตโมัติ
Pluse - width AFC  พัลซ์ วิดธ์ เอ.เอฟ.ซี.
Sawtooth - wave AFC  ซอ ทูธ - เวฟ เอ.เอฟ.ซี.
Filter circuit  วงจรกรองกระแส
Low - pass filter ฟิลเทอร์ชนิดหนึ่งที่ความถี่ต่ำผ่านได้ง่าย
High - pass filter  ฟิลเทอร์ชนิดหนึ่งที่ความถี่สูงผ่านได้ง่าย
FM (frequency modulation) เอฟ.เอ็ม
Fly - back line เส้นสะบัดกลับ
Horizontal retrace line  เส้นสะบัดกลับในแนวนอน
Vertical fly - back line  เส้นสะบัดกลับในแนวตั้ง
Front end circuit วงจรส่วนหน้า
Feedback circuit  วงจรฟีดแบค
- G -
gain  การขยาย
power gain การขยายกำลัง
voltage gain การขยายสัญญาณ
gain control ส่วนควบคุมการขยาย
AGC (automatic gain control)  ส่วนควบคุมการขยายอัตโมัติ
Keyed AGC คีย์ เอ.จี.ซี.
Grid  กริด
Generater เยเนอเรเตอร์
Sweep generater  ชวีพ เยเนอเรเตอร์
Marker generter  มารคเกอร์ เยเนอเรเตอร์
- H -
heater ฮิ้ทเทอร์
harmonics  ฮาร์โมนิกส์
- I -
input  อินพุต์
inducter  อินดัคเทอร์ , คอยล์
impedance  อิมพีแดนซ์ ์
- L -
line สาย , เส้น
feeder line  สายฟีเดอร์
twin - lead type feeder line  สายฟีเดอร์ชนิด สายคู่
coaxial cable line  สายโคแอคเชี่ยล
- N -
noise นอยส์ , สัญญาณรบกวน
- O -
oscillator ออสซิลเลเตอร์
local oscillator ออสซิลเลเตอร์ประจำวงส่วนหน้า
horizontal oscillator ออสซิลเลเตอร์ของวงจรหักเหทางแนวนอน
vertical oscillator  ออสซิลเลเตอร์ของวงจรหักเหทางแนวตั้ง
test oscillator  ออสซิลเลเตอร์ทดสอบ
oscilloscope  ออสซิลโลสโคพ
ohm  โอห์ม
- P -
pulse พัลช์
picture ภาพ
picture signal  สัญญาณภาพ
picture tube หลอดภาพ
plate เพลท
peaking coil พีคกิ้ง คอยล์
peaking resistor  พีคกิ้ง รีซิสเตอร์
potential difference ความต่างศักย์
phase - shifting network  วงจรเปลี่ยนเฟส
- R -
raster แรซเทอร์
resistor  รีซิสเตอร์ , ตัวต้านทาน
rectifier เรคติไฟเออร์
resonance เรโซแนนซ์
- S -
synchronizing pulse signal  สัญญาณซิ้งค
์  sync seperator circuit  วงจรแยกสัญญาณซิ้งค์
sync amplifier  เครื่องขยายสัญญาณซิ้งค์
scanning  การสแกน
sawtooth current  กระแสรูปฟันเลื่อย
signal  สัญญาณ
video signal , picture signal สัญญาณภาพ
composite video signal  สัญญาณภาพรวม
sound if section  สัญญาณเสียง
sideband แถบความถี่ข้างเคียง , ไซด์แบนด์
lower sideband  แถบข้างเคียงด้านความถี่ต่ำ
higher sideband  แถบข้างเคียงด้านความถี่สูง
snow  สโนว์
staggered tuning สแทกเกอร์ทูนนิ่ง
stray condenser  สเตรย์ คอนเดนเซอร์
- T -
television signal  สัญญาณโทรทัศน์
tuner  ทูนเนอร์ , วงจรส่วนหน้า
turret tuner  เทอเรท ทูนเนอร์
rotary switch tuner  โรทารี่ สวิทช์ ทูนเนอร์
TV transmitter เครื่องส่งโทรทัศน์
Thermister  เธอร์มิสเทอร
T.P. (test point)  จุดทดสอบ
- V -
voltage  โวลเทจ
- W -
wave trap  เวฟ แทรพ
wafer switch  เวฟเฟอร์ สวิทช์
somsak47 >บุคคลทั่วไป
« ตอบ #2 เมื่อ: 16 มกราคม 2005, 12:02:10 »
Alignment : (อลายเม้นท์)
คือการจัดวางแนว การจัดอลายเม้นท์ สำหรับหัวเข้มมีความสำคัญมาก หากผิดพลายไปจะทำให้เกิดความผิดเพี้ยนมาก หัวเข็มไม่ได้สัมผัสร่องในทิศทางและมุมอันควร ก็จะเก็บรายละเอียดได้ไม่ถูกต้องเช่นกัน
Amplifier : (แอมปลิฟายเออร์)
คืออุปกรณ์ที่ขยายความแรงของสัญญาณให้แรงพอที่จะขับลำโพงได้ การขยายสัญญาณจะแบ่งเป็นสองช่วงคือ ขยายสัญญาณอ่อนเรียกว่า pre-amplifier ส่วนนี้จะขยายสัญญาณให้แรงขึ้นมาระดับหนึ่ง ก่อนจะป้อนเข้าภาคขยายตัวจริงคือ power-amplifier หากจับทั้งสองส่วนรวมกันไว้ในตัวเดียวกันเขาเรียกว่า intergrated-amplifier
Analogue : (อนาล็อก)
หมายถึง ลักษณะของสัญญารที่เป็นคลื่นต่อเนื่องไปตามปกติ
Anti-skating : (แอนติ-สเภทติ้ง)
เป็นการปรับหัวเมให้มีแรงด้านต่อการตึงเข้าสู่จุดศูนย์กลางขณะที่กำลังเล่นอยู่ อาศัยกลไกของโทนอาร์มเป็นตัวทำให้มีแรงต้านนี้
Balanced : (บาล้านซ์)
วงจรไฟฟ้าแบบล้านซ์คือ วงจรที่จัดสัญญาณทั้งซีกบอกและซีกลบ ผิดจากสัญญาณปกติที่จะเป็นสัญญาณซีกบวกมาเทียบกับระดับอ้างอิง (ground) การต่อสัญญาณแบบ บาลานซ์ คือการใช้สัญญาณทั้งซีกบอกและลบซึ่งผ่านมาในตัวนำที่มีลวด screen ป้องกันการรบกวน ซึ่งนิยมใช้กันในสตูดิโอเนื่องจากต้องเดินสายสัญญาณเป้นระยะทางยาวและอาจถูกรบกวนจากภายนอกได้มาก
Bass : เบสส์
หมายถึง เสียงในช่วงความถี่ต่ำกว่า 160 Hz ลงไปซึ่งอาจแบ่งออกได้อีกเป็น 3 ช่วง
1 UPPER BASS : เบสส์ช่วงบนย่านความถี่ 80-160 Hz
2 MIDBASS : เบสส์ช่วงกลางย่านความถี่ 40-80 Hz
3 DEEP BASS : เบสส์ช่วงลึก ย่านความถี่ 20-40 Hz
ลักษณะของเบสส์อาจบรรยายด้วยถ้อยคำมากมาย เช่น
โด่ง/วูบ : บอกในเชิงปริมาณมากหรือน้อยของเสียงในช่วงใดช่วงหนึ่ง
หนา/บาง : บอกทั้งในเชิงปริมาณและลักษณะการทอดตัวของเสียงหลังจากที่ต้นเสียงเกิดขึ้นแล้ว เบสส์หนา จะมีปริมาณมากเกินควรและคงตัวอยู่นานเกินควรทั้ง ๆ ที่ควรจางหายไป เบสส์บาง จะมีปริมาณน้อยเกินควรและจางหายเร็ว
หนัก : เบสส์ช่วงลึกเป็นตัวให้ความหนัก
แน่น : การตอบสนองที่ฉับพลันทันทีเป็นตัวให้ความแน่น
หนักแน่น : เบสส์ที่ทั้งลงได้ลึกทั้งรวดเร็วฉับพลัน
เฉื่อย : ตรงข้ามกับความแน่น
บวม : ปริมาณออกจะมากเกินควรไปบ้างแถมยังไม่ค่อยเก็บตัว
Bass Reflex : (เบสส์รีเฟล็กซ์)
รูปแบบหนึ่งของระบบการทำงานของลำโพง อาศัยการอัดคลื่นอากาศในตู้ให้ผ่านท่อออกมาในช่วยเบสส์ ทำให้ประสิทธิภาพสูงขึ้นในช่วยความถี่ต่ำ Belt Drive : (เบ็ลท์ไดร์ฟ) ใช้ในการถ่ายทอดพลังงานจากมอเตอร์ไปยังจานหมุนของเครื่องเล่นแผ่นเสียงหรืออุปกร์อื่น ๆ วิธีการนี้จะลดอาการกระตุกหรือการทำงานที่ทำงานไม่ราบเรียบของมอเตอร์ให้ไปถึงจานหมุน
Bimping : (ไบแอมปิ้ง)
วิธีการต่อแอมปลิฟายเออร์เข้ากับลำโพง โดยแยกการขับวูฟเฟอร์ และทวีตเตอร์ให้แอมปลิฟายเออร์คนละตัว ในกรณีนี้ต้องใช้แอมปลิฟายเออร์สองตัว สายลำโพงสองชุดและการแยกสัญญาณต่างหาก Bias : (ไบแอส)
Bias : (ไบแอส)
ในกรณีแรกหมายถึงแนวโน้มของโทนอาร์มในเครื่องเล่นแผ่นเสียงที่จะแกว่งเข้าหาศูนย์กลาง ซึ่งแก้ไขได้โดยการปรับแอนติสเกทติ้ง ในกรณีที่สอง หมายถึง สัญญาณความถี่สู่งระดับอุลตร้าโซนิคที่ป้อนเข้าหัวเทปขณะบันทึกสัญญาณ และอีกกรณีคือ การจัดระดับไฟเลี้ยงเพาเวอร์ทรานซิสเตอร์
Bit : (บิท)
ข้อมูลทางสัญญาณดิจิตอล ซึ่งแบ่งเป็นช่วงจัยหวะสั้น ๆ ชุดของสัญาณอาจจะมเป็น 8 บิท 14 บิท หรือ 16 บิท ซึ่งจะบอกถึงความแรงของสัญญาณในจังหวะหนึ่ง ๆ ของเครื่องเล่นซีดี
Bitsteam : (บิทสตรีม)
วิธีการเปลี่ยนสัญญาณดิจิตอลมาเป็นอนาล็อกสำหรับซีดีตัวแปลงสัญญาณในระบบบิทสตรีม จะจัดการกับสัญญาณดิจิตอลด้วยความเร็วสูงกว่าระบบมัลติบิท (multi-bit) ทำให้มีความต่อเนื่องราบเรียบดีกว่า
Biwiring : (ไบวายริ่ง)
การต่อสายลำโพงสองชุดแยกสำหรับวูฟเฟอร์และทวิตเตอร์ลดการรบกวนในสายลำโพงเป็นการปรับปรุงที่ให้ผลในราคาย่อมเยา Bridging : (บริคจิ้ง)
วิธีการเพิ่มกำลังของแอมปลิฟายเออร์โดยรวมกำลังจากแอมปลิฟายเออร์ข้างซ้าย/ขวา มาขับสัญญาณแต่ละซีก (บวก/ลบ) ต้องการแอมปลิฟายเออร์อย่างน้อยสองตัวสำหรับสเตอริโอ
Cables : (เคเบิ้ล)
สายนำสัญญาณ โดมากอาศัยทองแดงเป็นตัวนำ การออกแบบโครงสร้างของตัวนำอาจต่างกันไป ฉนวนที่หุ้มอาจต่างกันไป สายนำสัญญาณอาจให้ผลความแตกต่างในเสียงได้เนื่อจากคุณสมบัติทางไฟฟ้า สายยิ่งยาวยิ่งให้ผลกระทบมาก
Cartridge : (คาร์ทริดจ์)
หัวเข็มเล่นแผ่นเสียง มีหน้าที่เก็บข้อมูลขึ้นมาจากร่องที่เขาบันทึกไว้เป็นลูกคลื่นรอยขยัก การทำงานอาศัยปลายเข็มรูดไปตามลูกคลื่นสร้างความเคลื่นไหวมาตามก้านเข็มทำให้มีแส้นแรงแม่เหล็กตัดกับขดลวดสร้างแรงดันไฟฟ้าขึ้นมา
CD+G : (ซีดีพลัสจี)
ตัวย่อสำหรับ CD และ Graphics หมายถึง ซีดีที่มีรูปด้วยเล่นจาเกครื่องเล่นซีดีธรรมดาก็ได้หรือหากจะให้ได้ภาพต้องใช้เครื่องเล่น CD-I
CD-I : (ซีดีไอ)
ตัวย่อสำหรับ CD Interactive เป็นการใช้ซีดีในการเก็บข้อมูลและการใช้งานในลักษณะที่มีการโต้ตอบ อย่างเช่นใช้สำหรับการศึกษา ซึ่งผู้ใช้สามารถเลือกข้อมูลที่ต้องการได้ หรือสำหรับวิดีโอเกมส์ ซึ่งช่วยให้ผู้ใช้สามารถโต้ตอบกับเครื่องได้
CD-R : (ซีดี อาร์)
ตัวย่อสำหรับ CD-recordable หมายถึง ซีดีที่บันทึกได้โดยผู้ใช้ แต่เป็นการบันทึกครั้งเดียวลบไม่ได้ อาจจะระบุให้ยกเลิดบางส่วนของแผ่นได้ ให้เสียงในลักษณะเดียวกับซีดี วึ่งเหนือกว่า DAT และ Mini Disc
CD-ROM : (ซีดี รอม)
เป็นการใช้ซีดีในแบบของตัวบันทึกข้อมูลสำหรับคอมพิวเตอร์ อาจบันทึกข้อมูลได้มาก เช่น เอ็นไซโคลปิเดีย อันนี้ไม่ค่อยเกี่ยวกับวงการสเตอริโอของเรานัก
Class-A : (คลาสส์-เอ)
แอมปลิฟายเออร์ ซึ่งทำงานได้โดยที่วงจรแต่ละซีกขยายสัญญาณทั้งบวกและลบพร้อม ๆ กัน เพื่อลด Switching Distortion ให้คุณภาพเสียงดีมากแต่ร้อน
Class-B : (คลาสส์-บี)
แอปลิฟายเออร์ ซึ่งทำงานโดยที่วงจรแต่ละซีกขยายสัญญาณเฉพาะบวกหรือลบเท่านั้น ประสิทธิภาพสูง แต่คุณภาพเสียงอาจไม่ดีนัก แอปลิฟายเออร์ทั่วไปจะทำงานในคลาสส์-เอบี คือมีไฟเลี้ยงอยู่ในระดับหนึ่ง พอจะเป็นคลาสส์เอได้ในช่วงที่ใช้กำลังน้อย ๆ
Colouration : (คัลเลอเรชั่น)
การที่เสียงมีการบิดเบือนไปจากของเดิม อาจเรียกได้ว่าเป็นการแต่งแต้มสีสัน มักจะไม่เป็นที่ต้องการในเวลาที่พูดกัน แต่อาจเป็นที่ต้องการเวลาฟัง ก็คนเรามักชอบความหลอกลวงแต่ปิดบังไว้ !
Compression : (คอมเพรสชั่น)
วิธีการลดเนื้อที่การเก็บสัญญาณในระบบดิจิตอล เช่น ATRAC ของโซนี่สำหรับแผ่น MD และ PASC ของฟิลิปส์สำหรับ DCC ลดอัตราความเร็วองข้อมูลที่จะใช้ในตัวเก็บ ในอีกกรณีหนึ่ง คือการปรับระดับความแรงของสัญญาณช่วงดังมาก ๆ หรือเบามาก ๆ ให้พอเหมาะกับคุณภาพของอุปกรณ์ที่ใช้
Crossover Network : (ครอสส์โอเวอร์เน็ทเวิร์ค)
อุปกรณ์ที่แบ่งสัญญาณออกเป็นสองหรือสามทางตามความถี่ที่กำหนด เช่น ความถี่สูงให้ไปทวีตเตอร์ความถี่ต่ำไปวูฟเฟอร์
DAC : (ดีเอซี) Digital-to-Analogue Converter
คืออุปกรณ์ที่แปลงสัญญาณในรูปดิจิตอลเป็นรูปอนาล็อกในเครื่องเล่นซีดี หรือ ดีเอที ล้วนต้องใช้อุปกรณ์นี้ อาจจะรวมอยู่ใรตัวหรือแยกเครื่องออกไปก็แล้วกัน
DAT : (ดีเอที) Digital Audio Tape
เครื่องบันทึกสัญญาณในระบบดิจิตอลลงบนเทป ใช้ในวงการอาชีพ ให้หัวเทปหมุนคล้ายของดีดีโอ ปัจจุบันเหลือใช้แต่ในสตูดิโอ
DCC : (ดีซีซี) Digital Compact Cassette
คิดค้นโดย Philips สามารถบันทึกสัญญาณดิจิตอลบนเทป ได้โดยอาศัยวิธีการ Compresssion และสามารถเล่นเทปอนาล็อกธรรมดาได้ด้วย
Decibles : (เดซิเบล)
หน่วยการวัดความเปลี่ยนแปลงจากแรงดันของเสียงเปลี่ยนไป 1 เดซิเบล หูคนอาจจับความแตกต่างไม่ได้ ในขณะที่ -10 เดซิเบลจะฟังเหมือนดันขึ้นไปเป็น 2 เท่า
Drect Drive : (ไดเร็คท์ไดร๊ฟ์)
วิธีการขับจานหมุนของแผ่นเสียง แกนของมอเตอร์จะเป็นแกนของจานหมุนด้วย ให้ประสิทธิภาพสูงในการถ่ายพลังงานออกตัวเร็ว ความเที่ยงตรงในการหมุนดี แต่อาจมีการสั่นสะเทือนจากมอเตอร์
Digital output : (ดิจิตอลเอาท์พุท)
เป็นสัญญาณดิจิตอลที่ออกมาจากเครื่องเล่นซีดีหรือดีเอที เพื่อที่จะผ่านเข้าสู่เครื่องแปลงสัญญาณ (DAC) หรือเครื่องบันทึกสัญญาณดิจิตอล อาจจะมาในรูปของสัญญาณไฟฟ้าหรือลำแสง
Distortion : (ดิสทอร์ชั่น)
สัญญาณที่ผิดเพี้ยนแปลกปลอมไปจากเดิม อาจมีในหลายรูปแบบ
Dolby Labs : (ดอลบี้ แลบส์
เป็นผู้คิดค้นระบบลดเสียงรบกวนในการบันทึกเสียง และระบบเซอร์ราวนด์ให้เสียงรอบทิศทางสำหรับภาพยนตร์
Dolby B,C and S : (ดอลบี้ บี,ซี แอนด์เอส)
ระบบลดเสียงรบกวนสำหรับการบันทึกเสียงโดยนักเล่นนักฟังทั่วไป
Dolby HX Pro : (ดอลบี้เอชเอ๊กซ์โปร)
ไม่ใช่ระบบลดเสียงรบกวน แต่ช่วยให้การบันทึกความถี่สูง ๆ ดีขึ้น
Dolby Surround : (ดอลปี้ เซอร์ราวนด์)
สำหรับโรงภาพยนตร์หรือวีดีโอเข้ารหัสสัญญาณสำหรับเสียงที่จะมาด้านหลังตำแหน่งนั่งฟัง เมื่อเวลาเล่นก็จะต้องมีเครื่องถอดรหัสเป็นสัญญาณด้านหลังมาประกอบกับเสียงสเตอริโอด้านหน้า
Drop out : (ดร็อปเอ๊าท์)
เกิดขึ้นระหว่างการบันทึกหรือเล่นกลับของเทป เมื่อเส้นเทปสัมผัสหัวเทปไม่สนิทหรือมีตำหนิบนเทป ทำใหัสัญญาณสูญหายไป
Dynamic Range : (ไดนามิคเร้นจ์)
เป็นช่วงของความดังที่แตกต่างระหว่างตอนที่มีสัญญาณดังที่สุดและเบาที่สุด จะบอกในหน่วย dB
Electrostatic : (อีเลคโทรสแตติค)
โดยมากจะหมายถึงลำโพงที่อาศัยประจุไฟฟ้าสถิตย์การทำให้แผ่นไดอะแฟรมเคลื่นไหว ลำโพงประเภทนี้มักจะมีรูปทรงเบา ๆ
Flutter : (ฟลัตเตอร์)
คือความไม่แน่นอนคงที่ของการเคลื่อนตัวของเส้นเทปหรือการหมุนของเครื่องเล่นแผ่นเสียง จะเกิดขึ้นแบบวูปวาวชั่วครู่ชั่วคราว
Frequency : (ฟรีเควนซี่)
ความถี่ของสัญญาณ เสียงแหลมจะมีความถี่สูง เสียงทุ้มจะมี ความถี่ต่ำ ช่วงความถี่ของเสียงที่มนุษย์ทั่วไปได้ยินคือ 20-20,000 Hz
Frequency Response : การตอบสนองความถี่
หมายถึง ลักษณะของระดับความแรงของสัญญาณที่ออกมาจากอุปกรณ์นั้น ๆ เมื่อได้รับสัญญาณที่ป้อนเข้าไป เป็นสิ่งที่แสดงให้เห็นความสามารถของอุปกรณ์ว่าสามารถทำงานได้ในช่วงความถี่ไหนและมีความราบเรียบถูกต้องเที่ยงตรงเพียงใด
Front end : (ฟร้อนท์เอ็นด์)
เป็นส่วนที่ให้สัญญาณมาก่อนถึงภาคขยายสัญญาณ ซึ่จะนับรวมตั้งแต่เครื่องเล่นซีดี จูนเนอร์ ไปจนถึงส่วนควบคุมปรับแต่งสัญญาณ
Hertz (Hz) : (เฮิร์ทซ์)
เป็นหน่วยของความถี่ หนึ่งเฮิร์ทซ์ หมายถึง หนึ่งรอบคลื่นต่อ หนึ่งวินาที
Horn loading : (ฮอร์นโหลดดิ้ง)
วิธีการหนึํงที่เพิ่มประสิทธิภาพของลำโพงโดยใช้อุปกรณ์ในลักษณะปากแตรวางไว้หน้าลำโพง
Imprdance : (อิมพิแดนซ์)
คุณสมบัติทางไฟฟ้าของวงจรที่มีสัญญาณ โดยกว้าง ๆ หมายถึง ความต้านทางของอุปกรณ์หนึ่ง ๆแต่ในความต้านทานนี้อาจแปรเปลี่ยนไปกับความถี่ได้ ลำโพงที่มีอิมพิแดนซ์ต่ำ (น้อยกว่า 4 โอห์ม) หรือมีอิมพิแดนซ์ที่แปรเปลี่ยนมาก ๆ นั้นต้องการแอมปลิฟายเออร์ที่มีคุณภาพสูงขับกระแสได้มากและเสถียรภาพดี
Laser disc : (เลเซอร์ดิสค์)
คล้ายแผ่นซีดี แต่มีขนาด 12 นิ้วและบันทึกสัญญานสองหน้า สัญญาณที่บันทึกมามีทั้งภาพและเสียง ทำมาสำหรับภาพยนตร์ในบ้าน ให้คุณภาพที่ดีกว่าวีดีโอเทปมาก
Line level : (ไลน์เลเวล)
ใช้สำหรับสัญญาณทั่วไปที่มีความแรงพอที่จะไม่ต้องขยายขึ้นอีกก่อนป้อนเข้าสู่แอมปลิฟายเออร์ กล่าวโดยง่ายก็คือสัญญาณทั้งหลายที่ไม่ใช่สัญญาณจากหัวเข็ม
MidRange : เสียงกลาง
หมายถึง ความถี่เสียงในช่วงกลาง อันเป็นส่วนหลักของย่านเสียงที่เราได้ยินกัน อยู่ในช่วงความถี่ 160-1,500 Hz โดยมากมาจากการเปรียบเทียบกับสิ่งต่าง ๆ รอบ ๆ ตัว มีทั้งศัพท์ฝรั่งและศัพท์ไทยหลาย ๆ คำ ก็ยากที่จะถ่ายทอดออกมาให้เข้าใจตรงกันได้ เช่น
ขึ้นจมูก : มาจากคำ NASAL หมายถึง เสียงคำที่ออกมาในแบบที่ถูกบีบจมูก เกิดจากเสียงที่โด่งขึ้นมาเป็นช่วงแคบในย่านเสียงกลาง LS3/5A ก็มีอาการอย่างนี้
เจิดจ้า : หมายถึง เสียงกลางที่ค่อนข้างจะโดดเด่นล้ำนำหน้าเสียงอื่น ๆ ทำให้ขาดความกลมกลืน เสียดุล
อัดหน้าอก : มาจากคำ CHESTY หมายถึง เสียงกลางช่วงต่ำที่มีปริมาณค่อนข้างมาก ทำให้เสียงผู้ชายทุ้มห้าว ลึกเกินควร
โปร่ง : หมายถึง ลักษณะเสียงที่ชัดเจนปราศจากการรบกวนจากเสียงอื่น ๆ นอกเหนือไปจากสัญญาณที่มา
Mini-disc : (มินิดิสค์)
พัฒนาโดยโซนี่ ขนาดครึ่งหนึ่งของซีดี ใช้เทคนิคคอมเพรสชั่นเพื่อให้บันทึกสัญญาณได้มากพอสำหรับเล่นกลับ 74 นาที บันทึกสัญญาณได้โดยผู้ใช้ มีซองหุ้มคล้ายดิสเกทท์คอมพิวเตอร คุณภาพยังเป็นรองซีดี
Monitor : (มอนิเตอร์)
โดยมากใช้กับลำโพง หมายถึง ลำโพงที่ใช้ในการตรวจสอบระหว่างการบันทึกเสียงหรือออกอากาศสำหรับสตูริโอ โดยปกติการออกอากาศจะใช้ลำโพงที่ให้ความเป็นกลางของเสียงจริง ในขณะที่การบันทึกเสียงจะใช้ลำโพงที่สามารถเปิดได้ดัง มีรายละเอียด
Monobloc : (โมโนบล็อค)
หมายถึง แอมปลิฟายเออร์ที่ทำขึ้นมาสำหรับการขยายสัญญาณข้างใดข้างหนึ่งโดยเฉพาะ ต้องใช้สองตัวสำหรับสเตอริโอ ลดการรบกวนระหว่างซ้าย/ขวา วางแยกกันได้สะดวก
Moving coil : (มูฟวิ่งคอยล์)
หัวเข็มที่ให้สัญญาณออกมาโดยอาศัยการเคลื่อนไหวของขดลวดที่ติดอยู่กับก้านเข็ม สัญญาณที่ได้มีกำลังอ่อน แต่มีข้อดีที่ให้รายละเอียดสูง
Moving magne : (มูฟวิ่งแมกเน็ท)
หัวเข็มอีกชนึดหนึ่งส่วนที่เคลื่อนไหวคือแม่เหล็กที่ก้านเข็มให้สัญญาณได้แรงกว่าแบบมูฟวิ่งคอยล์ นิยมใช้ทั่วไป
NICAM : (นิแคม)
วิธีการออกอากาศสัญญาณโทรทัศน์ให้มีคุณภาพเสียงเทียบเท่าซีดี อาศัยเทคนิคทางดิจิตอล ใช้ในอังกฤษและยุโรปบางประเทศ
Ohm : (โอห์ม)
หน่วยวัดความต้านทานไฟฟ้า ตัวเลขมากแสดงความด้านทานสูง กระแวไฟฟ้าผ่านได้ยาก
Oversampling : (โอเวอร์แซมปลิ้ง)
ใช้ในการแปลงสัญญาณจากดิจิตอลเป็นอนาล็อก เป็นเทคนิคในการกรองสัญญาณจากดิจิตอลและการอนุมานข้อมูลระหว่างช่วงของการแซมปลิ้ง
Passive : (แพสซีฟ)
วงจรหรือชิ้นส่วนอุปกรณ์ที่ไม่ต้องการไฟเลี้ยง ไม่มีขยายสัญญาณ ให้ดิสเทอร์ชั่นต่ำแต่ทำให้การสูญเสียสัญญาณได้
Phono stage : (โฟโนสเตจ)
ภาคขยายสัญญาณสำหรับหัวเข็มเล่มแผ่นเสียง นอกจากจะขยายสัญญาณแล้วยังต้องปรับแต่ลักษณะการตอบสนองตามมาตรฐานของ RIAA
Plinth : (พลิ้นท์)
อุปกรณ์ซึ่งเป็นส่วนรองรับส่วนที่เคลื่อนไหวทั้งหลาย อาจเป็นแท่นใหญ่ในกรณีของเครื่องเล่นแผ่นเสียง หรือเป็นตุ่มเล็ก ๆ รองรับเครื่องเล่นซีดี หรือลำโพง มีหน้าที่ตัดความสั่นสะเทือนด้วย
Power handling : (เพาเวอร์แฮนด์ลิ่ง)
กำลังสูงสุดที่ลำโพงสามารถรับได้ โดยที่ไม่ทำให้เกิดความร้อนหรือกรวยต้องเคลื่อนตัวเกินขีดจำกัด
Realism : ความเหมือนจริง
คำนี้น่าจะแปลว่าความจริง แต่มันเป็นความจริงของเสียงที่ถูกสร้างขึ้นมา ซึ่งอย่างไรมันก็ไม่ใช้ความจริง เป็นได้เพียงใกล้ความจริง เพียงความเหมือนจริง เสียงจริงมีคุณสมบัติของมันที่สร้างขึ้นมายากจากจากระบบเครื่องเสียง เพราะต้องผ่านขึ้นตอนต่าง ๆ มากมายจนถึงลำโพงที่ทำเสียงขึ้นมาใหม่ โดยไม่มีลักษณะคล้ายเครื่องดนตรีของเดิมเลย พิจารณาในแง่ต่าง ๆ เช่น
ความสด : หมายถึง เสียงที่มีความเร็วทันกับความฉับพลันของเสียงจากเครื่องดนตรีจริง และมีปริมาณที่ได้ใกล้เคียง ไม่มีการบีบอั้นจำกัดไว้ เสียงฟาดกลองฟาดฉาบแฉต้องออกมาเหมือนกับมีการสัมผัสจริง ๆ โดยไม่มีอะไรกั้น
ความใส : มาจากคำว่า TRANSPARENCY หมายถึง ความสามารถในการถ่ายทอดเสียงออกมาได้อย่างชัดเจนแจ่มแจ้ง ให้ได้รายละเอียดอย่างทั่วถึงไม่คลุมเครือ ไม่มีหมอกเมฆ ไม่มีสากเสี้ยน ปราศจากความฝ้ามัว เหมือนมองขึ้นไปยังท้องฟ้าหน้าหนาวยามเที่ยงในชนบท เสียงที่เราได้ยินจากเครื่องเสียงนั้นไม่ได้ใสบริสุทธิ์ แต่จะคล้ายภาพที่เห็นจากการมองผ่านกระจกหลายชั้น ซึ่งเกิดจากขั้นตอนต่าง ๆ ในการบันทึกและผลิตขึ้นใหม่
ช่วงความดัง : หมายถึง ช่วงความดับระหว่างเสียงที่ค่อยที่สุดกับเสียงดังที่สุด ในเสียงจริงนั้นอาจจะเป็นถึง 100 dB ระบบเครื่องเสียงทั่วไปจะทำได้ยังไม่สมบูรณ์ บางทีอาจทำได้ในแง่ของความดังจาก 40-120 dB แต่มักจะไม่สามารถรักษาความเที่ยงของอัตราส่วนระหว่างนั้นได้อย่างถูกต้องโดยตลอด
RF : (อาร์เอฟ)
ย่อมาจาก Radio Frequency เป็นสัญญาณในย่านความถี่ของคลื่นวิทยุ เป็นความถี่ที่สูงกว่าย่านความถี่เสียงมาก
RMS : (อาร์เอ็มเอส)
มาจาก Root Mean Square เป็นวิะการวัดค่าเฉลี่ยของกำลังโดยใช้รากที่สองของกำลังสูงสุด แทนที่จะเฉลี่ยจากผลรวมของกำลังสูงสุด ซึ่งเป็นทั้งบวกและลบ
Rumble : (รัมเบิ้ล)
เสียงรบกวนช่วงความถี่ต่ำที่เกิดจากกลไกการหมุนที่ไม่ราบเรียบสม่ำเสมอ
SCART : (เอสซีเออาร์ที)
ขั้วต่อสัญญาณแบบพิเศษที่ผ่านสัญญาณทั้งภาพและเสียงใช้ในการต่อเครื่องเล่นโทรทัศน์กับอุปกรณ์ภาพและเสียง
Sensitivity : (เซนซิติวิตี้)
หมายถึง ความไวในการตอบสนองต่อสัญญาณที่เข้ามา ความไวสูงก็ต้องการสัญญาณที่ไม่ต้องมีกำลังมากนักเซนซิติวิตี้ของลำโพงจะบอกเป็น dB/W/m หมายถึง ความดังของเสียงเมื่อป้อนสัญญาณเข้าไปหนึ่งวัตต์ โดยวัดที่ระยะห่างออกมาหนึ่งเมตร
Screening : (สกรีนนิ่ง)
หมายถึง ลวดตาข่ายที่จะเป็นตัวป้องกันการรบกวนจากภายนอก และอาจหมายถึงสิ่งที่ป้องกันการรบกวนของคลื่นแม่เหล็กไฟฟ้า หรือคลื่นอื่น ๆ ที่แพร่มา บางทีก็เรียก Shielding
S/N :
มาจาก Signal-to-Noise Ration หมายถึง อัตราความแรงของสัญญาณเมื่อเทียบกับสัญญาณรบกวน ตัวเลขยิ่งมากหมายถึงการรบกวนน้อย
Soundstage : (ซาวน์สเตจ)
นอกเหนือจากคุณภาพในเชิงปริมาณแล้ว ระบบสเตอริโอยังสามารถสร้างวงดนตรีจำลองขึ้นมาได้ ไม่เป็นเพียงแต่เสียงออกมาจากลำโพงโดยตรง แต่จะฟังเหมือนกับว่าสรรพเสียงต่าง ๆ กำเนิดขึ้นมาจากบริเวณรอบ ๆ ลำโพงมีความกว้าง และความลึกเป็นสามมิติบริเวณที่ว่า เรียกว่า ซาวนด์สเตจ
คุณภาพของซาวนด์สเตจจะมีในแง่ของความกว้าง ใหญ่ ความลึก สัดส่วนของความลึกเมื่อเทียบกับความกว้าง รายละเอียดและความสม่ำเสมอ การวางตำแหน่งของอิมเมจ
ความกว้าง : ระบบสเตอริโอที่ดีจะสามารถให้ความกว้างขอวงซาวนด์สเตจออกมาได้กว้างกว่าระยะระหว่างขอบนอกของลำโพงออกไปจรดหรือเลยผนังด้านข้างของห้องฟังขึ้นอยู่กับสัญญาณที่บันทึกมานั้น
ความลึก : ได้มาจากระบบที่สามารถให้ความเที่ยงตรงในแง่ของเลาและในแง่ของปริมาณของเสียงประกอบที่แรดซ้อนห้อมล้อมอยู่ จำให้การแยกแยะของเสียงต่าง ๆ ได้ว่าอันไหนอยู่หน้าอยู่หลัง
อิมเมจ : มาจากคำว่า IMAGE หมายถึงภาพเสมือนของต้นกำเนิดเสียงหรือเครื่องดนตรี ตำแหน่งของขนาดของอิมเมจจะต้องมีความมั่นคง มีปริมาณของตัวเองแยกย้ายกันอยู่ในซาวนด์สเตจ ในการบันทึกสัญญาณอาจทำมาให้อิมเมจมีการเคลื่อนไหวได้โดยมากอาศัยอุปกรณ์อิเลคทรอนิคส์ช่วย
Source : (ซ๊อส)
แหล่งกำเนิดสัญญาณ ซึ่งอาจจะเป็นเครื่องเล่นซีดีเครื่องเล่นแผ่นเสียงทำนองนี้
Stylus : (สตายลัส)
ปลายเข็มของหัวเข็มเล่นแผ่นเสียง มักจะสัมผัสร่องแผ่นเสียง และเก็บข้อมูลขึ้นมาจากรอยหยักที่เขาทำไว้ ทำด้วยวัสดุที่มีความแข็งและทนทาน เช่น เพชร มีขนาดเล็กมาก รูปร่างก็ต้องออกแบบกันอย่างพิถีพิถัน
Subwoofer : (ซับวูฟเฟอร์)
ลำโพงที่ออกแบบมาสำหรับการสร้างความถี่ต่ำมาก ฟ โดยเฉพาะ ช่วยเพิ่มช่วงกว้างการตอบสนองความถี่และลดภาระของลำโพงขนาดเล็ก
Tepe loop : (เทปลูป)
ขั้วต่อสัญญาณที่ให้สัญญาณออกมาสำหรับการบันทึก และรับสัญญาณการเล่นกลับจากเทป อาจใช้ต่อกับอุปกรณ์อื่น ๆ ได้ เช่น อีควอไลเซอร์หรือดพรเซสเซอร์อื่น ๆ
THX : (ทีเอชเอ๊กซ์)
วิธีการนำสัญญาณ จาก Dolby Pro Logic มาจัดการต่อ ให้ผลทางเสียงรอบทิศทางที่แยกแยะได้ชัดเจนขึ้น คิดค้นโดย Lucas film เพื่อใช้ในโรงภาพยนตร์และต่อมาแปลงมาใช้ในบ้านทั่วไป
Tonal Balance : ดุลย์ของน้ำเสียง
หมายถึง การตอบสนองความถี่ที่ยังไม่ราบ (อาจจะเรียบก็ได้) มีความโน้มเอียงไปด้านใดด้านหนึ่งหรือโด่งขึ้นมาในบางช่วงหรือวูบหายไปในบางช่วงความถี่เสียง ทำให้เสียงที่ได้ไม่เสมอกันตลอดย่านมีความเด่นหรืออ่อนมาทางเสียงในช่วงใดช่วงหนึ่งก็ได้
Tonearm : (โทนอาร์ม)
อุปกรณ์บนเครื่องเล่นแผ่นเสียง ที่เป็นตัวจับและควบคุมหัวเข็มให้เคลื่อนไปตามร่องบนแผ่นเสี่ยง
Transients : (ทรานเซี้ยนท์)
สัญญาณหรือเสียงที่เกิดขึ้นอย่างฉับพลันทันใด เป็นส่วนสำคัญที่ให้ความแตกต่างของเสียงดนตรีจริง ๆ กับเสียงจากการบันทึก
Treble : เสียงแหลม
หมายถึง เสียงในช่วงความถี่ 1,500-20,000 Hz เป็นเสียงในช่วงความถี่สูงที่จะให้ความสดใสมีชีวิตชีวา
คำที่ใช้บรรยายลักษณะของเสียงแหลมก็มีมากมาย เช่น
จัดจ้าน : หมายถึง เสียงแหลมที่มีปริมาณค่อนข้างมาก เพลงป๊อปมักจะมีการบันทึกเสียงมาในลักษณะนี้ บางคนว่ามันกรุ๊งกริ๊งดี
สว่างไสว : หมายถึง เสียงแหลมที่มากด้วยรายละเอียด คล้ายกับว่าเป็นช่วงที่แสงไปส่องมามากกว่าช่วงอื่น ทำให้เห็นภาพชัดเจนมากขึ้นกว่าส่วนอื่น ๆ
แข็งกระด้าง : มาจากบางความถี่ที่มากเกินควรเข้ามากวนเสียงที่ควรมี อาจมาจากสัญญาณภายนอกที่แทรกซ้อนอาจมาจากตัวของอุปกรณ์เอง
Tube : (ทยู๊บ)
หมายถึง หลอดสูญญากาศที่ใช้ในวงจรอิเลคโทรนิคส์ ใช้กันมาก่อนทรานซิสเตอร์ หลายคนติดใจเสียงของอุปกรณ์ที่ใช้หลอดสูญญากาศนี้ ชาวอังกฤษเรียก Valve
Tweeter : (ทวีตเตอร์)
ตัวขับเสียงความถี่สูงในลำโพง
Watt : (วัตต์)
หน่วยที่ใช้วัดกำลังของแอมปลิฟายเออร์ ตัวเลขยิ่งมากยิ่งเป็นที่ต้องการ แต่ต้องระวังมีวิธีการวัดมากมายที่จะทำให้ได้ค่าตัวเลขสูง ๆ เอาไว้โฆษณา
Wave length : (เวฟเล้งจ์)
ความยาวคลื่น หมายถึง ระยะทางที่คลื่นเดินทางในหนึ่งรอบคลื่น
Woofer : (วูฟเฟอร์)
ตัวขับเสียงย่ายกลางลงไปถึงต่ำ
Wow : (วาว)
อาการแปรเปลี่ยนความเร็วในแบบช้า ๆ เกิดกับเครื่องเล่นแผ่นเสียงหรือเครื่องเล่นเทป ทำให้เกิดเสียงที่ไม่คงที่
http://www.thaiavzone.com/technicalG/audio_avvocab.html
